Gerber file for simple PCB circuit
Jay1107
Joined Jul 9, 2020
15
I could probably come up with the Gerbers, but would need to have a copy of the sensor circuit you have if you want to incorporate it.
Or, By sensor do you mean you intend to use the pre-built board and just add the new one based in the drawing in the OP?
Re: "One board only. Sensor will be added seperate just as an attachment to other board " seems like a contradiction, is it one board or two??
Max.
Hello Max.
Good morning, Please find attached Sensor Circuit and Resistance circuit.
Please ignore that contradictory line, i was intended to write something and ended up with something which caused confusion. It will be one board with one main design. Individual parts will be added/attached on PCB.
Jay
Jay1107
Joined Jul 9, 2020
15
Max,
Operating Voltage : 2.5 ~ 6V. Operating Current : 130 ~ 220mA. Flow Rate : 80 ~ 120 L/H. Heat sink mostly not required. If you feel it may heat up on back to back use of Hand Sanitizer we will add.
1K resistance specification - 1/4W
Jay
Jay1107
Joined Jul 9, 2020
15
I think through hole is preferably because some components I need solder like 2 pin connector and resistor etc.
Is there any other option which u suggest M
Jay1107
Joined Jul 9, 2020
15
Dear Max, I will pull out dimension of all 4 items and part number of items. I will try as this have to find where I will get.
But I will try my best.
Jay
MaxHeadRoom
Joined Jul 18, 2013
30,818
If JLCPCB are doing the build also, they need to know the parts involved and what the board has spec'd in.
I have always populated the boards myself, so have never experienced getting them made.
Max.
Jay1107
Joined Jul 9, 2020
15
Max
I would love to take full product from you but it would be difficult to get delivery from you to my country.
Please find some details which i got as asked by you. Dont know whether these are things you are asking :( . IR sensor part number is FC-51.
Jay
MaxHeadRoom
Joined Jul 18, 2013
30,818
There is obviously some communication problems, I had gathered that you intended combining all the components onto one board, which won't be the case if you intend using the complete ready made board shown.
If you are intending to combine and produce ONE single board, then the part numbers/make/model of such things as the pot and connectors etc.
Max.
