Generate 1 to 255 Hz, variable and controlled by arduino
davidbr
Joined Apr 25, 2018
60
Yes
I tried with 555 (actually this is how I started my post ) because my intention was to control that 555 using a digital potentiometer.
ericgibbs
Joined Jan 29, 2010
21,572
hi,
I realise that you are intending to use a 555 and pot, but I am trying to help you explain why all your Arduino frequencies are giving a doubled count value on the tacho.
I am trying to give you an idea for a simple reference frequency so that you can test the tacho for 'level or edge counting'
Eric
This is a 10Hz Astable.
davidbr
Joined Apr 25, 2018
60
Ok, I don t have that 4u7 capacitor, I have 22u and 47u capacitors
Second thing, where should be output on your schematic?
Btw - I did schematic attached (rpm2.pdf) and is working but is not like I would. In the schematic attached I connected a 10k potentiometer between potm1 and potm2 and out to the device. I am not sure if this is answer your question
davidbr
Joined Apr 25, 2018
60
Update - I changed multiplier values in pwm library and I am close of what I want. So for the moment I will try make this work since is much easier to use only arduino timer
Will post some results after I have a conclusions
ericgibbs
Joined Jan 29, 2010
21,572
hi D,
On your circuit what is the purpose of R6,R7 & C10 .?
If you connected components directly to pin #3 you will change the frequency.
If you want a 50/50 square wave on the output, the best way is to add a buffer transistor, on pin #7.
Check this image.
E
28,295
If there is a stable frequency available in the arduino OS, then you can use a count-down counter to generate precise time intervals for high and low time periods of your square wave signal. But in addition, it is not that complex to use a binary counter IC to generate frequencies dividing down from a stable known crystal oscillator frequency. Probably faster to design than some program to run on that little arduino board, and far easier to understand exactly what is happening.
