For my CEMF pulse generator, I have come up with an upgraded design for a replacement trigger and drive circuit using a GAN FET and associated driver. My IRF840 was getting fairly hot and, as I've heard these new GaN-based FETs are very robust, that I would give it a try. Also, the proposed use of a driver chip is to reduce the shut-off time of the FET thereby increasing the voltage transient at the Drain.
The present circuit and the proposed one are shown in the attached images.
I have several queries about using the Driver and am not fully confident on whether I have all the pins I need connected, with the FET serving as a low-sided switch?
Firstly, I'm not sure if I need pins 5,10 & 16 connected in some way (chip pinout data is on the image). Also, I'm querying if I can use the same Hall sensor setup, with the BC5409, as a signal to feed the STDRIVEG600 chip? And what might the resistance be just before the Ferrite bead?
The use of the Ferrit bead and the DC-Link snubber (whatever that is) are both recommended in the spec notes for the GAN FET.
Thank you.
Thank you.
