full-bridge CLLC, high side Mosfet Vgs weird
Ian0
Joined Aug 7, 2020
13,317
What are you using as MOSFET drivers? It looks like coupling through the gate-drain capacitance, suggesting that the gate drive impedance is too high.
kinghero1989
Joined Aug 8, 2023
24
Thanks for your answer, I am using this driver, please check the attached picture, by the way, I am using the Mosfet UJ3C065080K3S
kinghero1989
Joined Aug 8, 2023
24
What weirdness are you concerned about?
Show the complete circuit schematic of what you have.
Thanks for your reply, it's just a Full bridge CLLC circuit, and the Vgs of the high side MOSFET get induced and self-turn-on. Would you please have a look at the attached picture I posed earlier?
38,946
I did.
But without a schematic of what you have (you do have a schematic, don't you?), I can't make an informed comment on your perceived problem.
38,946
Doesn't help much.
This seems to be game of 20 questions.
A schematic shows the complete circuit.
What are all the blocks with nothing to tell what's inside?
Danko
Joined Nov 22, 2017
2,256
These spikes, exactly at start of deadtime,
should be negative, not positive:
ADDED:
1. In your case it may be capacitive coupling between 15 V power supplies.
2. Check signal waveform on driver input
