4x full-bridge or 4x half-bridge load cells to one HX711
Jase009
Joined Aug 27, 2018
9
Need some insight into whether half or full-bridge load cells connected in parallel to one HX711 is the better choice.
As 4x half-bridge load cells is the usual component in household scales, what pitfalls could I face if I connect 4x full-bridge to one HX711? Power requirements will increase for one, what else do I need to consider?
ericgibbs
Joined Jan 29, 2010
21,573
Hi Jase,
Depending on the total resistance value of the 4 * Full bridges and the excitation current required, you may need to add the Excitation circuit as shown in this HX711 PDF.
The 2nd PDF gives information regarding parallel bridge connection.
E
