High Current Half-and Full-Bridge Devices
Bruce#
Joined Dec 13, 2018
5
I am interested in having someone design such a MOSFET circuit to generate current up to 300 to 600 A peak into an impedance of 50 mOhm and inductance of 100 nH at frequencies up to several hundred kHz. This is a paid assignment.
BobTPH
Joined Jun 5, 2013
11,662
Let's see, P = I^2R = 600^2 * 0.05 = 18000W.
I think I will pass, that's a bit beyond my level of comfort.
Bob
mvas
Joined Jun 19, 2017
539
One Mitsubishi 6-Pack, with all three (3) channels connected in parallel, in current sharing mode, acting as a single half-bridge, is a possibility.
Each channel ...
600 Amps Peak
300 Amps Continuous
Even if one channel turns on early, or one channel turns off late, that channel can momentarily carry the full 600 amp load.
Current Balancing via Temperature...
1.6 mOhms @ 25°C
3.0 mOhms @ 125°C <<< The hotter MOSFET will carry less amps
Effective Rds(on) is 0.5 mOhms = 1.6 mOhms / 3 channels
0.5 mOhms is 1% of the resistance of the 50 mOhm Load
Vdss = 150 Volts
Built-In thermistor to shutdown the device on Over-Temperature
Switching Speed ...
2 microseconds = ( Turn-On Delay + Turn-On Rise Time ) + ( Turn-Off Delay + Turn-Off Fall Time )
The Switching Losses must be computed at the max Switching Frequency
An appropriate Gate Drive IC must be added
https://www.mitsubishielectric-mesh.com/products/pdf/fm600tu-3a_e.pdf
Bruce#
Joined Dec 13, 2018
5
CORRECTION; Sorry, my mistake. The quoted specs are for a 4 cycle tone burst at a repetition rate of 100 Hz. Thus, each portion of the bridge is on for 4 x 10 usec; 100 times a sec for a duty factor of under 0.5%.
