Full Adder in Ltspice
ericgibbs
Joined Jan 29, 2010
21,625
hi 680.
As this is your college assignment, you should now be able to describe how it works as a Full Adder.
Post here, how you think it works and we can go thru it,
E
omkarshinde680
Joined Oct 7, 2020
36
hi,
Look thru this link, the Full Adder part.
This Logic IC solution has been duplicated by using that Diode network.
Are you able to compare the Logic and the Diode solutions and post a working theory.?
E
https://www.geeksforgeeks.org/full-adder-in-digital-logic/
i have actually already referred this link and gone thru it, i understood the logical gates with full adder but with diodes i am not at all getting a clear idea. I have posted below the slice of network i think is a fundamental unit of circuit
ericgibbs
Joined Jan 29, 2010
21,625
hi,
This is a composite image of the two circuits.
I have already started marking the lines to indicate the A=0, B=0 and /CYin condition. [left side vertical line]
You should be able to do the rest.
E
look here.
