Full Adder in Ltspice
omkarshinde680
Joined Oct 7, 2020
36
If you want a digital output, you're going to need more than one transistor.
A half adder takes an XOR and an AND gate. A full adder can be implemented with two half adders and an OR gate.
how do i get
Referring to a new article i have created this new full adder using diodes and resistors now
https://hackaday.io/project/11860-diodes-only/log/52981-diode-full-adder
how do i get output in this?
omkarshinde680
Joined Oct 7, 2020
36
omkarshinde680
Joined Oct 7, 2020
36
ericgibbs
Joined Jan 29, 2010
21,622
hi 680,
Did you see this clip from that site.?
It requires inverted and true inputs for A, B, and CarryIn, and output buffers for Sum, CarryOut and /CarryOut, but that's only 6 inverters.
E
omkarshinde680
Joined Oct 7, 2020
36
hi 680,
E
what is actually meant by inverters here i read that but i didnt understand that actually should i simply attach voltage cells with step inputs like u and I did in the previous file and for inversion reverse the polarity?
Alec_t
Joined Sep 17, 2013
15,160
Since you need AND, XOR and OR functions I suggest you make and test those individually first; then you can bolt them together as appropriate.
As with most circuit designs and simulations, it helps to break the problem down into sections and get each section working first.
omkarshinde680
Joined Oct 7, 2020
36
hi 680,
This is a starting point for testing.
I think the circuit is 'Yuk!' lacking many features, give it a go and add any changes.
I dont have the 74hct14 inverter in my Ltspice library what else can I use in its place? Or can u please send me its .txt file so that i can import that into my circuit
omkarshinde680
Joined Oct 7, 2020
36
hi 680,
A tidier version of the circuit.
Set the Puls High/Low periods for A,B, CYI to suit your sim.
E
hello thanks a lot for your help! "Set the Puls High/Low periods for A,B, CYI to suit your sim" can you please elaborate this ? if possible can u please send me that file so i can import it into my LTspice.
ericgibbs
Joined Jan 29, 2010
21,622
hi,
You must add the Values as shown here.
Look at the LTS Help if you wish to set other parameters.
Right click on the Inv symbol to bring up the window
E
BTW: there is also a Schmitt symbol in Digital, you may need to the Threshold levels to suit,
ericgibbs
Joined Jan 29, 2010
21,622
hi 680.
Looks OK to me.
Please post your LTS asc file.
When is the next step in the project.
E
Update:
Are you trying to satisfy all the possible states.?
omkarshinde680
Joined Oct 7, 2020
36
hi,
E
I have set the High and low parameters of V u have mentioned to me however i dont see any changes in output waveform
ericgibbs
Joined Jan 29, 2010
21,622
hi 680,
The point I am making is that the test pattern of A, B CYi , of the LTS is set to prove the OR function.
In order to check the full adder operation you need to modify the A,B CYin test voltages , so that you get all the possible input states.
Do you follow what I am saying.
E
