Frequency indicador (?). How to make? (tone coded remote control)
RootElectronics
Joined Aug 16, 2018
I'm here to want help for my project. So I want to make a transmitter to switch on one of seven LED. Here is my idea: I will use a normal FM transmitter and receiver. Instead of audio jack of microphone on the input of the transmitter I will put a 555 timer oscillator that will can generate 7 different frequencies (I choose the one). The idea is when the receiver unmodulate the signal the LED have to activate from the frequency. I want to ask you how to make a circuit that activate DC on the output when we have a specific frequency on the input. For an example - I choose 350 Hz but I put 300 Hz, 400 Hz or else on the input - the LED is off. I put 350 Hz on the input and the LED is on.
Thanks you!
P.S.: I know about the LC circuit but for me it is for high frequencies.
Reloadron
Joined Jan 15, 2015
7,891
I would just run with a DTMF Encoder / Decoder. A Google of DTMF encoder decoder will give a few dozen hits. Most will give you 12 channels like a standard telephone keypad.
If you want to build your own decoder chips like the LM567, LM567C have been around for decades.
Ron
