MisterBill2
- Joined Jan 23, 2018
- 28,367
Of course, if this is a class project as part of the class then that is a different concern. A pump driven venturi is one possible method. A burst of higher power would be from a second battery, charged along with the first battery, but switched into a series connection for a short period based on a current level being exceeded. That would be hard on the pump but for 15 to 30 seconds it may not cause any damage.I agree with KISS. When dealing with waste water from a washer, the best solution is to trap the lint before it goes into the drain. That is a must for septic systems and is also required in some municipalities. Lint filters (sock like) are widely and inexpensively available.
