For a fpga, how can i determine maximum number of pins I can use for pwm ?
ashokraj
Joined Feb 1, 2018
151
Hi, I come from the background of microcontroller design. I am learning fpga design. Usually in the ucontrollers the total number of pwm is limited as per the vendors. In FPGA how can i determine the maximum number of pwm I can drive from a fpga. For example, currently i am working with microchips Smart fusion2 SOC. It has a microcontroller subsystem + fpga embedded in one chip. I would like to know the maximum number of pins I can drive PWM output pins.
Link
As per the link above, The total number of I/0 lines in TQ144 package is 84 lines, So does it mean I can use all the 84 pins as input and ouput pins ?
Thank you,
Ashok
Deleted member 115935
Joined Dec 31, 1969
Link
Thank you,
Ashok
In a FPGA
you are designing the silicon,
pin wise, to a first approximation, every pin is available as a PWM output,
they are what ever you design them to be , in put , out put, tri state, low speed, high speed, 3v3, 2v5 1v8 ,
its up to you
There are limits with every chip / design that you have to stay inside,
but they are also to a large extent up to your design,
A small for instance that might be relevant,
Most FPGAs have a "limit" on the maximum number of IO that can switch in the same direction at the exact same instance, due to ground bounce,
But for a PWM, that could be counteracted by phase shifting the different PWM outputs,
As an FPAG can easily clock at 100's of MHz,
then 10 ns phase shifting is really no problem,
DickCappels
Joined Aug 21, 2008
10,661
In custom chips, on the other hand, it may be very difficult to get a fab house that will gaurantee a minimum delay and I knew of a case in which designs that used gate delays declined to bid on production, so the customer had to lie about the function of the stacked up inverters.
ronsimpson
Joined Oct 7, 2019
4,672
Yes you probably can use all 84 I/O pins.
You might need a pin for clock input and a reset pin. Some FPGAs have internal clocks. You might need some pins to talk to the FPGA. SPI or I2C bus.
Lets say that you have 80 PWMs in the FPGA. So they all turn on at the same time and each can turn off by what value is in a register. It is not a good idea to have all the I/O pins switch at the same time. I have made FPGAs with almost all pins used for PWM. I broke the PWMs into groups and shifted the groups so only 8 pins would switch at one time.
Joined Dec 31, 1969
Re can you use all 84 pins as input / output
You need to look at the data sheet for your specific device.
Some pins might be pre configured as input or output only
some might be clock input only
Do some research on your particular chip.
