ronsimpson
- Joined Oct 7, 2019
- 4,694
The LT1170/1171/1172 should never see a voltage on the SW pin that is above 65 volts. (LR117xHV=75V)
I do not know what the input voltage range is. At mix input voltage the Zener needs to keep the SW voltage below 60 volts.
Different subject: Reversing D6 will reduce the AC loss inside the transformer. If you wind the two secondarys at the same time they will couple better. (+12V and -12V cross regulation)
