ronsimpson
- Joined Oct 7, 2019
- 4,793
The slope compensation should be used if duty above 50%,The duty cycle varies with the output power.
Without slope compensation flyback converters go unstable above 50%.
You are getting very close to continuous conduction mode, which is to be avoided as it will result in reverse recovery losses in the secondary rectifier.
The overshoot on Vds seems rather large, which would explain the snubber losses
The transformer design step is as follow:Please show how you made the transformer? It looks like the primary and secondary are not coupled well.
Just as important as how you calculated the number of turns, is where you placed the windings, and physically how you wound it. It’s behaving as though your primary and secondary aren’t even on the same bobbin!Please show how you made the transformer? It looks like the primary and secondary are not coupled well.
Thanks for the helpful information, but I can't really understand the Transformer build diagram really means.I know you have nothing to do but this is a good read. power
Page 12 has good information on how they made their transformer. They have a inductance vs leakage inductance of 450uh vs 5uh. while you have 42:12uH. See how little time it takes to dump the energy in the leakage.
Page 25 shows wave forms.
