Hi, everyone. I'm building a 110VAC-12VDC 120W Flyback converter using UC3842, and have some problems with the start-up circuit and output PWM signal.
In the beginning, the design spec at first:
Input: 110VAC
Output:12VDC 10A
Switching frequency: 107kHz
Transformer core: PQ35/35 (unknown manufacture, but reference the TDK datasheet to design)
Ae:196mm2
The turns number of primary, secondary, and auxiliary is 33:4:5
Switch: P20NM60 NMOS 600V/20A/0.25Ohm
Diode: STPS30150 Power Diode 150V/30A/0.69V
I reference the datasheet schematic and other friend's circuit, draw the schematic like this:
Schematic pdf
edit 20/12/16
P.s Modified as #14
New issue #17 about the PWM duty cycle problem
And the PCB layout looks like this:
And the whole board looks like this:
I'm facing two problems:
1. The start-up circuit
I'm using a 50kOhm 1/2W resistor as a start-up resistor, and an 18V Zener diode to limit the Vcc voltage of IC.
There is two 100uF capacitor parallel to maintain the Vcc voltage.
Thought I think it can handle the power consumption of the UC3842, but actually, the IC repeat startup and shutdown.
The voltage of the IC is like below, CH1 is the oscillator of UC3842, which is the Rt1 and Ct1 pin in the schematic, and CH2 is the Vcc pin of UC3842.
As you can see, the IC repeat start-up and shutdown means the IC can not start switching the input voltage, so auxiliary winding is not working.
The datasheet of UC3842 says that the start-up current of IC is just 1mA, so can anyone help me check the circuit and find out where the problem is?
2. No PWM output
To bypass the start-up circuit problem, I try to use another Lab power supply to provide the UC3842 power.
Like the picture below, the IC seems to work fine because the reference voltage of IC is established,
so the oscillator works like the picture below.
But the output of the PWM pin is still not working.
So I check out the layout and components, there is nothing wrong.
Then I try to build the circuit on a breadboard, which contains Rt1, Ct1, and Vcc.
The UC3842 is also no PWM output, too.
Conclusion:
Is the start-up circuit of my schematic any wrong or any clue to find out the problem?
Why the PWM is not working even I import the external DC power supply with no current limit?
Very thanks for your reply
Have a nice day.
Input: 110VAC
Output:12VDC 10A
Ae:196mm2
Schematic pdf
edit 20/12/16
P.s Modified as #14
2. No PWM output
Conclusion:
Have a nice day.
