FlipFlop-Latch - power up condition
eetech00
Joined Jun 8, 2013
4,724
p.s. is it possible for you to send me the spice file - can you attach that here?
Would make life easier for me to get started with the program and I can amend it as required ...... :D
Yes...but the smart switch is not a real smart switch model. I made it using a existing mosfet model just for this thread. Give me a few minutes..
DEcosse
Joined Jan 26, 2011
15
Thank you for all your effort - amazing!
Shouldn't make any really difference on the switch - why I just showed as mosfet for simplicity
The armed source will also be powered on at the same time as the power circuit - it has the quirk that when it is first powered on, it always comes on in the not-armed state.
So when power first applied the Not-R input (armed is high) means /q will be low.
Then when Not-R goes low, the device flips;
when not-R goes high it remains in that state.
Edit - Sorry I think I misunderstood - you're calling Vin the gate voltage!
But still don't understand the Vq & V/q responses in the timing diagram
V q & V /q is not showing correctly in your model - surely when power first applied to the flip-flop then q will be high and /q will be low;
then when the armed input (Reset) goes low, bottom gate will make /q high and so also make top gate flip to low out on q;
Not sure why it's why showing what it does in your timing diagram? it should look like I show in my last timing diagram
I think problem is that Vq is starting out low
That was the idea for the timing capacitor on the input of the top gate (0.1 is probably not big enough) - that would ensure that input starts at a low while is not charged
So at power-on Vq would have to be a 1; then it would be unchanged as the capacitor charges and Vq would still be high;
only when not-armed goes low will it flip over and then remain so
eetech00
Joined Jun 8, 2013
4,724
The digital models are good.
I think the problem is the arm signal is feeding back thru R2. Try changing R2 to 1N4148 diode (anode connected to NAND output, cathode connected to gate)
DEcosse
Joined Jan 26, 2011
15
... I think the problem is the arm signal is feeding back thru R2.
Ahh, that may be it - although V /q is staying high, which means it's actually Vdd through R1 (and R2) that would have to be doing that.
I am truly grateful for your help, especially creating the model - if I could impose just a little bit further:
I can't get the model to run - It errors with
Could not open Library file C:\users\user01\Documents\LTspiceXVII\lib\cmp\standard.mos
I put that file from your zip into the cmp library but it still comes up with that error ?
(of course User01 is my own User directory)
eetech00
Joined Jun 8, 2013
4,724
I tried this and it worked. R1 is OK. Just change R2 to a 1N4148 diode.
Edit the file "smartsw_nmos.txt"
Look for the line containing:
.lib C:\Users\user01\Documents\LTspiceXVII\lib\cmp\standard.mos
Change this path to:
.lib standard.mos
Then in LTspice, goto "Simulate->Control Panel->Netlist Options".
Check the checkboxes "Default Devices[*]" and "Default Libraries[*]" if not already checked.
then click OK.
Should work after that.
eT
DEcosse
Joined Jan 26, 2011
15
Been learning how to work my way around LTspice - but huge thanks to @eetech00 for getting me going with the starting circuit loaded.
First thing I had to do was reverse the Varm so that it starts high, then switches low - the arm device always comes on with a Not-Armed signal, which is the very issue I needed to overcome.
The diode doesn't work - it needs to biased other way around in order to sink the gate to ground through the Nand; but that still doesn't do it when trying to make the logic work along with the armed signal
Then that word 'logic' actually registered and I had a Eureka moment
And didn't even need any extra components with those gates already unused and available!
It's now doing exactly what I wanted - and the LTspice was invaluable in getting it figured out.
Here's the final result
eetech00
Joined Jun 8, 2013
4,724
Good job!
That actually was going to be my next suggestion..
Glad it worked..
eT
