Doubt you will get much simpler than the 555 circuit in my post #8.Trying to find the minimum components that will fit in about 1 inch cube space in the cigarette adapter.
Circuit below with increased resistor values, to lower the capacitor values and thus make them physically somewhat smaller:
Don't think you will see any damaging spikes in your application.I may need to protect the circuit from voltage spikes using an automotive transient voltage suppressor (TVS) and a 47 ohm resistor so that will also take up some space. Not really sure if these will be needed or not.
The large spikes noted in the literature are mainly from a load dump (sudden removal of the battery connection with the engine running) and that seldom happens.
But be sure and add the shown 68µF capacitor between the V+ and ground for filtering.
