Flashing LED for 10 seconds using one 555 chip
Unfortunately, a 10,000 uf, 50 volt cap that I checked on Amazon is 1.38 x 2.76 inches. Much too big to fit in a cigarette lighter adapter. Also, I assume that the brightness of the LED will fade to off as the 10 second delay expires. It is as simple as it gets though ... :)
I'm not suggesting the use of a 10k uf cap, its just a demo.
I think this is the simplest (same as post #45) and most compact. Be aware that some blinking LED's will need a series resistor. Also be aware the timing is dependent on supply voltage, RC time constant, and Mosfet VGS(th) values.
So you'll have to tune RC to obtain values for the desired timeout.
