Ahh 4.7K I see.For a start, your resistor values are way to low. They should not be 4.7ohms!
Try 4.7K ohms.
If you have used 4.7ohms, the 555 may now be dead.
Or use an X-Acto knife to cut the trace.For the strip board you also need a 3mm - 1/8inch drill bit to open up a trace.
There is little chance of cutting your self or cutting a neighboring strip if you use an 1/8" drill bit. If you have strong hands, you can just put the bit into a hole, spin the bit a few turns and the trace will be divided at the hole. Most major US companies have tightly regulated the use of X-acto blades and utility knives and razor knives because finger tips get cut off so often - especially when cutting along a ruler. Hand injuries are the most common injuries according to OSHA and lacerations are the most common hand injury. Avoid these knives if possible and use the drill bit method. That is even safe for students and you can clearly see when the cut is done. X-acto blade cuts aren't always obvious when you are through so people keep cutting snd cutting until they see a gap. Finally, the 1/8" bit is the safe cut so you don't accidentally cut into a neighboring trace but using a fatter bit makes the twist a lot more productive and easier for people with weaker fingers.Or use an X-Acto knife to cut the trace.
It is easier to cut the trace at a both sides of a hole.
However, if you want to save the hole you can cut the trace in between where there is no hole.
You can use any prototyping boards that fit your needs and budget. For simple circuits like yours, I'd use perforated phenolic board.1) PCB Boards - anything special or are they all similar?
I use #30 Kynar type wirewrap wire for most things.2) What type of wire (gauge) is typical to use on the PCB board to solder? I can probably get that on Amazon, right?
If you take the time to do a board layout, you can maximize the use of bare wire.Any other advice is always appreciated.
