Fixing Acrade Basketball IR Scoring Mechanism
myersgg
Joined Dec 30, 2014
10
I have an old arcade basketball game with an infrared scoring mechanism, but the baskets are not being counted at all. I love this game and it is no longer sold so I'm hoping someone can point me in the right direction for fixing the scoring mechanism (here is the game http://www.competitiveedgeproducts.com/detail.aspx?ID=636 )
My thinking is that either the IR sensors have gone bad or that something is messed up in the wiring to the scoreboard, it turns on and counts down, but no baskets are ever recorded (it used to work very well). Any idea if this can be fixed and where my best bet would be to start troubleshooting (i.e. wires or IR sensors or somewhere else)? Is there someone that I can hire to take a look or is that probably not worth it and I should try myself? Any help would be greatly appreciated, I love this game and I'm really hoping to get it back to working order!!
Thanks!!
Greg
Note: I saw there was sort of a similar post in 2010 but it seems he had a slightly different issue where his was inaccurate but working, whereas mine used to be accurate but has since completely stopped working.
M. White
Joined Jan 2, 2015
2
Myersgg, Did you have any luck resolving the issue? I have the same game, same problem, and just started looking for a way to resolve it. Let me know if you find a solution.
Thanks
mwhite
cmartinez
Joined Jan 17, 2007
8,861
If it is indeed an IR sensor at the basket, then it must have an emitter and a receiver. I'd start by locating them both and posting pictures of them. They could be damaged, disconnected due to vibration, or simply misaligned.
cmartinez
Joined Jan 17, 2007
8,861
Ok, first I'd suggest you checked for conductivity in the cables of each sensor and emitter... I'm assuming you do know how to use a voltmeter, right? If not... I'd suggest you hired someone to do the job for you
myersgg
Joined Dec 30, 2014
10
I've been away but I'm back now if more pictures or anything would help. I don't know how to use a voltmeter :(. Do you know how I would go about hiring someone to help? Or any easy things to try before I go that route? Thanks!!
cmartinez
Joined Jan 17, 2007
8,861
For starts, you may try your local appliance servicing workshop... most people capable of fixing a refrigerator or a microwave will be capable of helping you... just make sure to get an estimate before you green-light the guy...
Brevor
Joined Apr 9, 2011
297
M. White from your first picture you can see the emitters are working because they glow in the photo, I would suggest looking at the wiring of the detectors for breaks.
cmartinez
Joined Jan 17, 2007
8,861
I'd start there too... but he doesn't know how to use a voltmeter.. unless, of course, the problem is a disconnected wire... if the problem is a broken wire then he'd have to check for continuity.
If you're willing to spend $10.00 dlls at your local Radio Shack on a very cheap (but very useful) voltmeter, I'm willing to help walk you through the basics of this project of yours
Brevor
Joined Apr 9, 2011
297
Are you the same C. Martinez from 8052. Com ?
cmartinez
Joined Jan 17, 2007
8,861
I know the site... but I haven't been there for ages and ages... so I'm probably not the same guy you're referring to...
BTW, I do consider myself pretty good with the 8051 architecture... not to brag... just saying in case you need something related to that subject
myersgg
Joined Dec 30, 2014
10
Hmm I don't think my sensors glow, I'll take a better look when I get home. So even though they are IR sensors there should be some visible light from them?
bertus
Joined Apr 5, 2008
23,006
You could try to look at the IR emitor with a digital camera.
A lot of them will show a white dot when they are exposed to the IR.
cmartinez
Joined Jan 17, 2007
8,861
Now, THAT I didn't know... that's gonna come in handy in my line of work...
do you think a smartphone's camera will do the trick too?
Brevor
Joined Apr 9, 2011
297
No not the sensors, the emitters. See the first picture in post 5. It's not visible to the naked eye you need to use a digital camera.
myersgg
Joined Dec 30, 2014
10
OK update for me, I tried with a camera that can see IR light and there is no light coming from those emitters. Tested on a remote and it saw the light but nothing from these emitters. Any idea what my next step would be?
cmartinez
Joined Jan 17, 2007
8,861
Check for continuity in the cables that connect the emitters and the receivers to the main board... using the $10 dlls voltmeter that I suggest you give yourself as a late christmas or early valentine's present...
myersgg
Joined Dec 30, 2014
10
Voltmeter arrived today! I'm at work now but I'm sure I'll be back with questions once I get it fired up. So as I understand it I would want to set it to continuity test and touch both ends of each wire to ensure the current goes through them? Should I also plug the system in and check for power coming from the wires that go to the emitters? ...and if so what setting would I use for that? Thanks!!!
