Fixed mate for a pillow block flange bearing?
spinnaker
Joined Oct 29, 2009
7,830
As long as the power requirement is low you could perhaps make a small rotary transformer? A bit more involved than a slip-ring, though.
Thought of in another thread but I would rather go with ehe slip ring if I can. I lot more straight forward to transfer data,
spinnaker
Joined Oct 29, 2009
7,830
I am toying with the idea of creating my own slip rings. What about bearing s placed over a shaft? Wires would be soldered to inside and outside ring. The shaft would need to be make of an insulating material or have an insulator placed between bearing and shaft.
shortbus
Joined Sep 30, 2009
10,049
All I need is power. I also plan to have a shift register on the spinning board that will tun on and off LEDs. I really haven't figured out the frequency yet but should be fairly low. Certainly under what the shift register could handle.
When you first posted about building this i didn't know how they worked so did some research. The one good (I thought) build had a lot of basic information on the things that seem to be needed. When you said "frequency" were you meaning, the disk RPM? According to that guy 3600RPM was the right speed.
Here is the link, maybe it will give you some ideas. http://www.pyroelectro.com/projects/pyro_propeller_clock_pov/
spinnaker
Joined Oct 29, 2009
7,830
No frequency I meant data transfer. I need to do the math but I would need to divide the circle up into a number of "slots". I would need to transmit 8-10 bits in the time it is in the slot.
But I would rather not get mired down in the actual working of the clock. Just concentrate on how i can power and transmit data to the spinning board.
cmartinez
Joined Jan 17, 2007
8,857
Hey! ... that was my suggestion ...
spinnaker
Joined Oct 29, 2009
7,830
I assume there is conductivity between outer ring and inner ring?
Any thoughts on an insulator placing the bearings on an aluminum tube? I was thinking painting the aluminum with not conductive paint but I would be concerned about scratching the shaft when placing the bearings.
cmartinez
Joined Jan 17, 2007
8,857
Yeah, you could cut a piece of sheet plastic and wrap it around the shaft, or you could also use shrink wrap
spinnaker
Joined Oct 29, 2009
7,830
My concern with that is matching the size of the bearing with the size of the tube. Adding that extra material might make the job difficult.
killivolt
Joined Jan 10, 2010
836
Is he trying to generate voltage? Why not just put a Toroid and some magnets, as the outer turns with the magnets the Toroid puts the voltage out to his LED's. Unless he's trying to be discrete minimizing things so you can't see how the voltage is being created. I'm confused:oops:
kv:(
spinnaker
Joined Oct 29, 2009
7,830
Been a few years but I did quite a bit using nylon material from McMaster Carr Supply. You could buy nylon in about any shape you could want. You could also drill and tap the stuff as well as use nylon screws and nuts for mounting boards on it.
Ron
In your opinion how thick should I go with nylon? I would think the shaft would not be more than 5-6 inches long.
Roller skate bearings are pretty popular and cheap. The are 8mm inside.
https://www.ebay.com/itm/20-Ball-Be...850688&hash=item1c9653d6fd:g:1BkAAOSw4CFYwKlO
Would 8mm be thick enough to prevent sagging or bending? I do plan to set the bearings in a wooden block or two.
Edit: I am thinking of going with a tube, that way I can run the wires inside the tube.
spinnaker
Joined Oct 29, 2009
7,830
So to answer my question. I assume there is connectivity between the outside and inside rings of the roller bearings? Is it reliable enough for data? I.E no interruptions in connectivity?
cmartinez
Joined Jan 17, 2007
8,857
There will be interruptions, most definitely. The bearing's internal lubricants will cause intermittent contact, which is something easily fixed if what you're trying to do is transmit power, but not if you're trying to perform serial communication, for instance.
spinnaker
Joined Oct 29, 2009
7,830
What I suspected but not what I wanted to hear. :( I wonder if I wouldn't have issues with interruption of data with my store bought slip ring too??
