EDITED: FIXED Fluke 5100B calibrator
Rufinus
Joined Apr 29, 2020
323
Edited, the problem was a wrong connection, thank you again
Hello. I friend of mine got a FLUKE 5100B. It seems to work, it turns on and let my put all the different values, but it doesn’t send any voltage to the output. We have tried everything (or at least i think that)
I know this is a very vague question. I just ask it in case it is a usual/typical problem, like a fuse or something. Any idea?
thank you
best regards
28,182
If there are over-voltage or over-current settings in the setup, make sure that they are not set at zero. THAT was the fault on a nice power supply that I got because "it did not work." Certainly a simple thing to repair.
