fix broken 75ohm antenna jack on home stereo
albsure
Joined Apr 1, 2012
15
Hello World.
Long story made short, the center signal terminal broke away on my stereo receiver's FM antenna jack. It just pulled straight out, as if it broke off at the source.
Anybody have a DIY fix idea? As far as I can tell, it just needs a conductive adhesion to the plate or terminal stub, whatever is inside.
Inside of the stereo, this antenna jack is connected to a receiver module that appears to be inseparable, so I can't get in to see if it's replaceable.
thanks in advance.
abrsvc
Joined Jun 16, 2018
164
This is a common part on many receivers. Post the make and model of the unit and I will see if I can locate a similar one on a parts unit. I don't know of a source for these since these are rarely broken.
Dan
