Glenn Holland
- Joined Dec 26, 2014
- 703
The rise time of an IGBT is much quicker than a bipolar switch (such as a GTO) and that is one part of the problem. However, the total problem must take into account both the "Intrinsic" variable (the effect of the rise time of the IGBT itself) and the "Extensive" variable (the switching rate). One pulse cycle alone will not cause an immediate problem, but the effect is cumulative and millions or billions of cycles will eventually puncture the insulation.Why is it that IGBTs specifically were a problem? I don't know of anything special about them that would cause a problem. Other than turn-on/off time. If the turn-on/off time was too fast it would cause HV spikes, but that's a function of the drive circuitry, not the IGBT itself.
By the way, the development of the IGBT was largely based on research by Japanese elevator companies who wanted a solid state alternative to generator field control which was the world standard for elevators and the largest application of variable speed drives. In fact, most Japanese elevator companies are also subsidiaries of electronic device (and also magnetic material) manufacturers such as Mitsubishi, Hitachi, Toshiba, etc.
In the 1980s, the editor of one of the elevator trade and engineering journals in the U.S. conducted an interview with the lead engineer of one of Japan's elevator manufacturers on the future of research and development in elevators. He made a rather astounding statement that "Innovation in the field of elevators must now begin at the molecular level". His statement emphasized that the problem of making improvements in elevators was a parallel to the problem of improving computers. For elevators, this meant that motor controls would require drastically improved power electronic devices such as SCRs, Mosfets, and ultimately IGBTs, all of which the parent company would develop in its semiconductor division.
To provide a mechanical platform for their electronic research, Westinghouse licensed it's elevator technology to several Japanese firms who developed prototypes of solid state controls that were used by Westinghouse in the U.S.
