Female socket for multimeter leads?
18,133
Any idea what this is called, or if it exists? I'd like to have a female socket to mount in a project, into which I could place my multimeter probes and have a reliable connection. A test point, if you will, but reasonably solid.
I could just put in alligator clips to grab onto the DMM pins, but I'd prefer something neater.
Sort of related question: Is there a decent and cheap LED voltmeter that I might mount on a PCB? I wouldn't need a DMM if I could just build a voltmeter into the project. I've seen some cheap ones appear in this forum but not with glowing reviews as I recall. I don't need great accuracy but repeatability matters.
GopherT
Joined Nov 23, 2012
8,009
I've see one project use springs -like from a retractable ball-point pen. Twist right to push in, twist left to pull out. Not exactly panel mount but at least an idea.
Bernard
Joined Aug 7, 2008
5,784
Just tried a pin jack with 2 mm test probe- perfect fit, but only had one. If a DVM OK, have spare Red Lion MDMV0000. 200mV, 1 pA, 15 pins panel or board mt; just postage.
