USB-C to HDMI (Female) at 3 ft (1 M)
Status
Not open for further replies.
Tonyr1084
Joined Sep 24, 2015
9,744
I've found some USB-C to HDMI Female cables but they are all on the order of a few inches. Does anyone know of one that is about 2 to 4 feet in length?
wayneh
Joined Sep 9, 2010
18,180
I don't. It looks like the industry has decided that a "regular" (male-to-male) HDMI cable is what you'll use to cover distance. Everything else is a short adapter.
Frankly I don't disagree. The HDMI cable will hold its value longer than an adapter. I have a drawer full of various adapters that are now obsolete but every HDMI cable I own is in current use.
Tonyr1084
Joined Sep 24, 2015
9,744
The HDMI I'm using for my big screen TV is 10 feet long. It's just short by about 2 1/2 feet. I air-play but the only thing I can get is screen mirroring. I'd like to make a drawing on my computer then move the picture to the big screen so I can see dimensions from across the room rather than having to walk back to the computer to get a dimension. Air-play helps but I can't work on other stuff at the same time (relatively speaking).
The TV is over a stairway. I'd have to build scaffolding just to reach the TV. Even moving the cable would require the same thing, scaffolding. A short adapter would make a world of difference in ease of solving the problem.
rcmtinker
Joined Mar 2, 2024
Amazon has a bunch for sale from 1foot to 10feet usb.I had no idea they even existed .. Ill be getting one for sure.
Tonyr1084
Joined Sep 24, 2015
9,744
Glad you discovered something you can put to good use. Note that I was looking for a USB-C to HDMI FEMALE connector with a length of approximately 3 feet. I found what I'm looking for. Glad you found something too.
[edit]
Your profile shows you've been an AAC member since March of 2024. Yet you only show a single post. If you're new to AAC - Welcome to AAC.
[end edit]
28,485
OK, I had not realized that USB-C was fully intended to make other connections obsolete. Not to offer any real benefit actually. Other than a slight amount of convenience for a few users.
Status
