Problem Description
I can't upload a sketch on an ESP8266EX with ArduinoOTA library (using ArduinoIDE 1.8.13), which is on a PCB I designed (Crystal frequency: 40MHz and Flash size: 4MB --> Mfr. Part: HT25WD40ARZ and LCSC Part: C2928800).
The code used is the BasicOTA example given for the "Generic ESP8266 Module" boards. The code I want to upload is essentially the same.
The PCB is perfectly functional, and the serial upload works very well.
I first tried with version 3.1.2 of the board manager on the Arduino IDE, then with the latest version of git.
Plus, firewall is disabled.
In my research I saw that it could be a problem related to the size of the Flash memory, but I tried all sizes without success.
https://github.com/esp8266/Arduino/discussions/7955
When uploading serially I get this output:
It's showing me a flash size of 512KB when I've designed the card with 4MB, which is odd enough, but it works.
MCVE Sketch
Debug Messages
I get the result on the ESP's serial port at update:
and sometimes depending on the Flash memory selected (here: 512KB, FS: 32KB OTA: ~230KB):
This is what I get from the console of the IDE for the sketch I want to upload:
Basic Infos
Platform
Settings in IDE
C:
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 40MHz
MAC: a4:e5:7c:27:00:93
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 512000
Changed.
Configuring flash size...
Auto-detected Flash size: 512KB
Flash params set to 0x0300
Compressed 320112 bytes to 231885...
Writing at 0x00000000... (6 %)
Writing at 0x00004000... (13 %)
Writing at 0x00038000... (100 %)
Wrote 320112 bytes (231885 compressed) at 0x00000000 in 4.9 seconds (effective 525.2 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
MCVE Sketch
C:
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#ifndef STASSID
#define STASSID "your-ssid"
#define STAPSK "your-password"
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
void setup() {
Serial.begin(115200);
Serial.println("Booting");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
// Port defaults to 8266
// ArduinoOTA.setPort(8266);
// Hostname defaults to esp8266-[ChipID]
// ArduinoOTA.setHostname("myesp8266");
// No authentication by default
// ArduinoOTA.setPassword("admin");
// Password can be set with it's md5 value as well
// MD5(admin) = 21232f297a57a5a743894a0e4a801fc3
// ArduinoOTA.setPasswordHash("21232f297a57a5a743894a0e4a801fc3");
ArduinoOTA.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH) {
type = "sketch";
} else { // U_FS
type = "filesystem";
// NOTE: if updating FS this would be the place to unmount FS using FS.end()
Serial.println("Start updating " + type);
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) {
Serial.println("Auth Failed");
} else if (error == OTA_BEGIN_ERROR) {
Serial.println("Begin Failed");
} else if (error == OTA_CONNECT_ERROR) {
Serial.println("Connect Failed");
} else if (error == OTA_RECEIVE_ERROR) {
Serial.println("Receive Failed");
} else if (error == OTA_END_ERROR) {
Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println("Ready");
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
void loop() {
ArduinoOTA.handle();
C:
Start updating sketch
Progress: 0%
Progress: 0%
Progress: 0%
Error[4]: End Failed
C:
Progress: 0%
Progress: 0%
Progress: 0%
Progress: 1%
C:
. Variables and constants in RAM (global, static), used 29064 / 80192 bytes (36%)
║ SEGMENT BYTES DESCRIPTION
╠══ DATA 1496 initialized variables
╠══ RODATA 1392 constants
╚══ BSS 26176 zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 60543 / 65536 bytes (92%)
╠══ ICACHE 32768 reserved space for flash instruction cache
╚══ IRAM 27775 code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 287064 / 1048576 bytes (27%)
╚══ IROM 287064 code in flash
An error occurred while uploading the sketch
Uploading.................................................
15:08:09 [ERROR]: Error Uploading
- I have tested that the issue is present in current master branch (aka latest git).
- I have searched the issue tracker for a similar issue.
- I have filled out all fields below.
Platform
- Hardware: [ESP8266EX]
- Core Version: [latest git hash]
- Development Env: [Arduino IDE 1.8.13]
- Operating System: [Windows]
Settings in IDE
- Module: [Generic ESP8266 Module]
- Flash Mode: [DOUT]
- Flash Size: [4MB]
- lwip Variant: [v2 Lower Memory]
- Reset Method: [dtr]
- Flash Frequency: [40Mhz]
- CPU Frequency: [160MHz]
- Upload Using: [OTA]
- Upload Speed: [115200]
