I am having a hard time figuring out how to fix this warning. It says that that symbol '0v' is connected to a net with two different NetNames. It refers to the other symbol located on the upper right which is 'Vpp'. It tells me that I need to change the name or remove the symbol at all. I don't know what's the problem with this since I followed the given schematic diagram to us properly.
Please refer to the attached images below. Thank you.
Edit: I am using the ExpressSCH Software.
Edit#2: Added the actual .sch file
