Explanation of the Stator winding
electronicsLearner77
Joined May 26, 2012
127
I am referring to the synchronous motor, if the stator is having 3 coils with 120 Degree separation, what is the reason it is called a 2 pole stator? Please explain.
MaxHeadRoom
Joined Jul 18, 2013
30,759
Four pole 3ph motor winding example sequence, A two pole motor is the minimum pole count and will run at the applied frequency, e.g. 60Hz = 3600rpm.
Max.
