Explain about time domain and phasor domain in electrical circuit
WBahn
Joined Mar 31, 2012
33,175
What is the actual homework problem you are being asked?
We won't just answer your homework for you. We will help guide you along the path to answering it yourself.
nguyengiathinh
Joined Jul 4, 2022
14
It's really problem when I study AC circuit in electrical circuit. I don't know it clearly
WBahn
Joined Mar 31, 2012
33,175
Go back and look at the development of the phasor technique. Go through the same process that was used to find the current through a resistor that is being powered by a voltage source. Go through the same process that was used to combine two resistors, capacitors, or inductors that are in series or parallel.
Then, to really see the beauty of it, go through the process of finding the current in a capacitor or an inductor connected to an AC voltage source (in steady state). Solve the differential equation and compare this to using phasors. Then do the same for a series RC circuit. At that point you should be a true believer.
Linear circuits are described by linear differential equations. One technique that can be used to solve such equations are Laplace transforms, which turn a differential equation into an algebraic equations, that are then solved using the normal techniques that apply to systems of linear equations, and then the result is transformed back into the time domain.
When you write the phasor form of a sinusoidal signal or the complex impedance of a capacitor or inductor, all you are really doing is taking the Laplace transform of it.
nguyengiathinh
Joined Jul 4, 2022
14
When you mention to Laplace transform and linear circuit. I really think that I need to do. Thank sir
WBahn
Joined Mar 31, 2012
33,175
Have you learned about Laplace transforms yet? It's not uncommon for students to learn phasors before they do, which makes it hard to really grasp what is going on as opposed to having to just take things on faith.
