Error with creating a equation in ADS with the variable already defined on the schematic asVar
kintaro
Joined Jun 1, 2022
16
I am trying to create a equation to plot the eye diagram from the voltage node Vout
As I define the equation, it tells me that the "Tbit" is not defined!?
I wonder why because I have already defined it on the schematic in the 'Var" icon
Does anyone know?
ZCochran98
Joined Jul 24, 2018
356
Ah, that's because it's defined as an equation variable that's local to the schematic/design file, and cannot be seen by the output file. To do this, look for the "measurement equation." The measurement equation will actually be shared between both the schematic/design file and the simulation output file. It also allows for you to use that variable in optimizations as well. HOWEVER, to use the measurement equations, you might have to also define all of the equations that measurement equation uses as measurement equations as well (thankfully, the window to do that works in the same way that the standard equations are, if I recall correctly).
Edit: The last sentence may be incorrect; you may be able to use the local equation variables within a measurement equation, but I don't quite remember.
kintaro
Joined Jun 1, 2022
16
Thank You!
