Error when simuling my circuit with LTspice.
astro01
Joined May 3, 2017
3
I'm newbie in electronic and with LTspice usage.
I try to use XOR gate with dflop component.
My circuit is in attached file of this topic.
When i replace my XOR gate by AND gate or OR gate, it's work.
But when i use XOR gate, i have this error :
Analysis: Time step too small; time = 0.001, timestep = 1.25e-018:
trouble with dflop-instance a1
I don't understand why i have this error with XOR gate and not with AND gate.
Thank you for your help,
38,521
What exactly are you trying to do with the XOR gate?
I think the problem is that there's a conflict between the XOR output and what the FF is trying to do.
If you put a small RC delay between the XOR and the D input, it will simulate without error.
eetech00
Joined Jun 8, 2013
4,705
Add some prop delay to each device... about 2n using TD=2n parameter
astro01
Joined May 3, 2017
3
Thank you for your answers.
To add the delay, right-click the component symbol and enter 'td=2n' in its Value field.
I make a delay on XOR gate and it's work.
I try to make a 8 bits register and increment it for each clock cycle.
Why i must make a delay on XOR gate and not for AND gate ?
astro01
Joined May 3, 2017
3
Look at the logic.
I believe you have a race condition.
Why do you think you need an XOR gate?
They are not usually used for that purpose.
Because XOR is used for make addition.
What do you preconise ?
I thought to do like this schema for increment a 2 bit register.
But i have always 0 in Q out of A3 and A2.
