error in checking lvs test with calibre tool in cadence ic
tia2017
Joined Mar 23, 2017
24
hi i'm trying to apply lvs test to the layout of my circuit that is a transimpedance amplifier which uses 4 spiral inductors .the problem is when i try to check lvs it gives me the following errors :
no matching ".SUBCKT" statement for "SPIRAL_STD"
source can not be read
what should i do to solve this ?
thanks in advance.
WBahn
Joined Mar 31, 2012
33,074
Are you sure the file containing that subcircuit definition is in a place where it can be read and is properly formatted?
tia2017
Joined Mar 23, 2017
24
the technology file of spiral inductor is in the tsmc13rf folder if thats what you mean. what do you mean by properly formatted ?
tia2017
Joined Mar 23, 2017
24
My problem has been resolved . the problem was that rule file for 0.13 technology was not included in lvs rules window . i added rule file for 0.13 technology and then problem solved
tia2017
Joined Mar 23, 2017
24
sorry i made a mistake .problem was not rule file . it was because of netlist file . in the lvs tool i went to inputs menu and then i selected netlist and then i added this address to the files /usr/local/IC614/tsmc13/techFile/Calibre_LVS/source_added.RF_12_25_FSG
my cadence version is 6.14 .i hope this is helpfull for somebody who has the same error.
