Error in book or my error?
Petrovic
Joined Aug 10, 2012
4
Hi, I just registered. I am a bit stucked at an example exercise. When I work out the integral (bottom of the picture) I get -V/jnπ. The two zero-limits of the integrals give both -V/jnπ , the other limits should give -2sin(nπ)/jnπ which always is zero.
Because the resolution of the above picture is a bit low I link to an extra picture.
I always assume at first that I make a mistake when I get a different result but I can't find any mistake.
@Moderators: I guess it would be better if the title would be: electronic circuits - error in book or my error?
33,171
The book answer given is correct. We can't begin to point out where you made your mistake unless you show us your work.
t_n_k
Joined Mar 6, 2009
5,455
Your working is correct thus far. Try evaluating your result at any odd value of n and your answer will agree with the book result.
33,171
You're doing fine. You just need to finish things.
You could massage things to replace the complex exponentials with a trig formula, or you could just take note of the fact that 'n' has to be an integer and consider what the results are when n is even and when n is odd.
You're very close.
Petrovic
Joined Aug 10, 2012
4
I think I understand it.
When n is odd you get -1 for e^j*n*pi = cos(n*pi) + j*sin(n*pi) because cos(n*pi) = -1 and sin(n*pi) = 0 for n is odd. The same for e^-j*n*pi = cos(-n*pi) + j*sin(-n*pi).
33,171
Yep, that'll do for when n is odd.
Be sure you do the same thing for n even to see that those terms vanish.
