Can you tell me what the C11 and C4 capacitors are doing in your simulation? Are they showing possible oscillation? Or are they added to try and reduce output transistor heating? I can't easily follow what you were doing in layman's terms.#35 -- hints that it is a precision target application - - - while the simulators give you usually a general overview of the circuit interrelations logic = it suggest how (not by how much) to adjust component parameters (with the simulators there is always tendency to go too idealistic -- precise tuning the resistor values that most definitely won't match those on the real circuit ...) /// besides the BUL6823 used has the hFE 12...22 (although it tolerates 400V collector voltage) it goes far from design you are working on
your design is principally done (well/) out of the book -- they just untied the Load GND from the regulator 1 ...
________________
did and a Gizmoless sim. that shows that the transformer (i came up with) needs to be more powerful = the demanded power starts to exceed that provided just about at 55V OUTP (e.g if there were a SC protection as in your circuit and/or a shunting zener -- it wouldn't work/regulate at all)
(another thing not tested is high power draw at low output voltages = at high power at regulator-switch transistor) - there is no limitting resistor needed for a darlington switch at moderate output currents (it should be re- verified for max. (near SC(short circuit)) currents) etc. etc.
View attachment 188235+ about the "AND" View attachment 188245 View attachment 188246 View attachment 188247 View attachment 188248
they illustrate the possible behaviour of the (power) "switch" of the emitter load voltage regulatorwhat the C11 and C4 capacitors are doing in your simulation
.So maybe the inefficiency of design is designed that way?
| Thread starter | Similar threads | Forum | Replies | Date |
Is it OK to Step down from 800V to 24V with Emitter Follower like this? | Power Electronics | 28 |
