AlbertHall
- Joined Jun 4, 2014
- 12,663
You won't get any output at all with C1 connected as shown.
If, in the power supply rectifier section, you remove the ground connection from the negative terminal of the bridge rectifier and instead connect it to the transformer at terminals 6 and 7, which is functionally the secondary center point, that might bring the input voltage down to a level that would give very little heating of the transistors. You might need to use a higher value of capacitance at the filter, C3.Here is the actual full circuit, attached. I have tried doubling output transistors (both of the Darlington set up- 4 transistors). I have also tried 2 Mosfets (R5- 100 ohm base emitter resistor removed and Q2 removed- base emitter jumped) with 1 ohm source (what would be emitter) resistors tied to output (temps were a little uneven 20F between), but this worked. If I can use the 2 fets I could use one heatsink, with fet on each side of the heatsink. I suppose I could also replace the other 2N6308 in the negative output lead with a fet, just don't know the resistor value changes to do that.
There's an option for a switch there, must be jumped if just turning off and on the AC (the other option). See attached.You won't get any output at all with C1 connected as shown.
There's a switch across C1 (or jumper), not shown. C2 is the power supply filter. C3 was added when some oscillation was found Q1 base to emitter, but removed when it was found not doing anything. I need the adjustability to 80VDC, this is for different coils that need specific voltages applied, staying the same voltage with AC line change. So lowering the AC volts is not an option.If, in the power supply rectifier section, you remove the ground connection from the negative terminal of the bridge rectifier and instead connect it to the transformer at terminals 6 and 7, which is functionally the secondary center point, that might bring the input voltage down to a level that would give very little heating of the transistors. You might need to use a higher value of capacitance at the filter, C3.
And right now I am wondering how you get any voltage out with C1 in series with the DC line. Are you certain it is in the right place? It does not look right.
Thanks,@ #1
you might try to introduce a cople of resistors
1-st to Q1 collector (in order to reduce momentarily current through it , and lower it's probable V.CE . . . also enabling more current through Q2 as it reduces the neg. collector feedback of Q2 -- is precision tuning)
2-nd from the base of Q2 to GND or to it's emitter (to make it base voltage more stable)
perhaps a cap (100pF up to 100µF) across 2N3055 C-E (← but this is relational design element that may need more mod.-s to the circuit -- while it has any effect to your problem at first place - must be verified that the problem with 2N3055 is it's oscillating with inductive load - must be verified that shunting the power switch has suppressing effect on such ← may require to redesign the circuit and at the input side to 2N3055 ... )
What is a shunt capacitor on Q5 (emitter to collector?).? is the Q4 emitter connected as shown on your figure or is there something missing/not-so . . . or then it's Q3 , D5
if the connections are as shown you want to AC shunt the Q5 with large capacitor . . . and maybe some more schematic adjustments
perhaps you write next to each block of your schematic what it was meant to do/handle
do not ANDI can experiment with resistors on Q1 collector and Q2 base
you can intercept the TF from high side and regulate from there ←← but this rises the difficulty level of your design by order of 2(as from 1 to 3)So change the transformer voltage so that the regulator input is only 6 volts above the desired output and there will be much less heat generated.
If you put a resistor in each emitter of the parallel transistors it will help to balance the current between them. The resistors should drop about 0.3V at the current which will be flowing in each transistor.
in this system with a lower load current I suggest using one ohm resistors.
50*√2≈71 with no load ← but that drops fast to 36V with considerable load presentIf you drop the 75 volts AC input to 50 volts that should give about 60 volts at the collectors of the pass transistors
_____________________place a series resistor between the filter and the regulator with a bypass switch across it
The inductive load is a magnetically engaged brake. The voltage must be at 52 to 58 volts to release the armature. But different size brakes will need different voltage ranges to do this. The fast shut off has something to do with allowing no flux to prevent the magnet part of the brake from re-engaging. I am not sure of this, I am helping an engineer redesign an old control that was hand wired- transistors mounted to a metal plate, now components are on 1 pcb not hand wiring, but way hotter running, because no plate. The idea was to eliminate the hand wiring.what is 300mA inductive load . . . exactly = everything else depends what kind of regulation it does need
+ about the "AND"
| Thread starter | Similar threads | Forum | Replies | Date |
Is it OK to Step down from 800V to 24V with Emitter Follower like this? | Power Electronics | 28 |
