Hi everyone, if ya can spend a sec... I need some advice. I have a really noisy motor and I'm having some troubles suppressing it's EMF (I think).
SO I'm after some general advice for cleaning up 5us +- 1v noise. I've put a whole bunch of .1 uf caps all over the place - IE across the motor terminal, between each terminal and the jacket of the motor (Big improvement there)... across the output of the linear regulator across the power in of my Processor (arduino uno). Just .1 uf SMD on the underside of the GND and +5v.
the thing is If I scope out the 5v on the chip I still see power ripples on the chip. (I solder a little wire to the underside of the GND and the 2 5v pins)
the ripple is 5.6v... obviously it hangs...
Any Suggestions on how I can suppress this more. Should I be using perhaps a bigger cap... (it's a pretty fine signal...)... the motor's are .1uf THC... and were else I can I use SMD's.
It feels like some how the wires from the motors are acting like a transmitter and the power wire (or the legs of the chip itself) is acting like a receiver... is that even possible, the wires do run parallel?... again... I'm not after a magic bullet, but some general advice.
If ya know a good book, or online resource I'm happy to go there, but a quick google only gives me captian obvious advice (flybackdiodes and power filters).
Cheers!
Cheers!
