Emergency pond air supply.
dayasri
Joined Apr 23, 2018
7
If you feel comfortable with 240 AC, then something like this should work.
https://www.ebay.com/itm/NEW-Deltro...025934&hash=item3d3022ac1c:g:6ZwAAOSw9GhYdCIB
You will need some type of enclosure. They also have enclosed relays and sockets for more money. But you will still need an enclosure for the AC connections.
Your AC power line switch will control this relay. This relay will route AC line to your pump as long as there is ac line voltage. When the line fails....the relay will connect the battery to the inverter.....and switch pump input to inverter output.
Does that make any sense?
Thanks. I'll try this.
dayasri
Joined Apr 23, 2018
7
After you decide on your system control......you might consider a water pump. It is more efficient to pour the water thru the air.....than the air thru the water. As mentioned.
Is the pond stream fed?
its not stream fed pond. I'm using
I'm using 35000lph pump. But sometimes its 90'F. just want to make sure O2 exchange is happening by using an air pump when power out.
dl324
Joined Mar 30, 2015
18,455
Personally I’d be more concerned at the food in my fridge/freezer spoiling due to an extended power outage – than any fish in a pond.
That's a personal decision. Some pond fish cost thousands of dollars each.
I wouldn't care to have fish that depend on me die slow, avoidable deaths. Even if they started out as $0.29 feeders.
dl324
Joined Mar 30, 2015
18,455
Do you have aquatic plants? They'll produce O2 during the day and provide shade to keep the deeper part of the pond cooler.
Is your pond overstocked (more fish than it can support on its own)?
dayasri
Joined Apr 23, 2018
7
not over stocked . I have 25 large koi in my 11m x 8m x 1.5m pond.
