Emergency pond air supply.
dayasri
Joined Apr 23, 2018
7
Hello everyone, I want to make my pond air pump turn on automatically when power is out.
I'm going to use my 12v 20ah deep cycle battery, battery charger and 150w inverter. My pond airpump is 10w 240v.
I can run the air pump with the battery and inverter without any problem as long as i'm there to turn it on.
1. Can I use something to make it automatic ? Like turn the pump on from battery when power goes out like an emergency light.
2. Emergency lights turn of when ther's mains power and turn on when power cuts. So do I have to use a second pump as my everyday pump or can I use only one pump ?
please help. circuit diagram and things I need.
thanks.
dl324
Joined Mar 30, 2015
18,454
If it were me, I'd just buy a UPS and plug the pump in it. When power is lost, the UPS will power the pump. When power is restored, the UPS will switch to line voltage and charge the UPS battery.
BR-549
Joined Sep 22, 2013
4,928
If you feel comfortable with 240 AC, then something like this should work.
https://www.ebay.com/itm/NEW-Deltro...025934&hash=item3d3022ac1c:g:6ZwAAOSw9GhYdCIB
You will need some type of enclosure. They also have enclosed relays and sockets for more money. But you will still need an enclosure for the AC connections.
Your AC power line switch will control this relay. This relay will route AC line to your pump as long as there is ac line voltage. When the line fails....the relay will connect the battery to the inverter.....and switch pump input to inverter output.
Does that make any sense?
38,762
If you have a smart battery-charger then you may be able to just run off the battery-charger, battery, and inverter all the time, rather like a UPS.
The charger will run the inverter (which should only take an amp or two), as well as keep the battery charged, when AC power is available.
When the AC quits, he battery will continue to run the inverter.
Hymie
Joined Mar 30, 2018
1,347
Don't want to loose my fish. Thanks .[/QUOTE]
Fish and other underwater pond life that require oxygen to survive have developed the ability to extract the dissolved oxygen in the water. Having a fountain or other splashing of the water will increase the dissolved oxygen – but oxygen will naturally dissolve in a body of undisturbed water. So your fish will be in no danger whatsoever in the event of an extended power outage.
During my childhood I kept a goldfish in a bowl that survived for quite a while with no aerator or other disturbance of the water to increase the dissolved oxygen content.
So while your proposed project might have a noble purpose – its actual benefit will be zero to none.
ebp
Joined Feb 8, 2018
2,332
Oxygen content of water can be extremely variable in natural circumstances. Massive fish kills due to oxygen depletion in natural lakes are not uncommon. Dissolved oxygen content of water is heavily contingent on temperature, algae and other plants, light (because of its influence on plants), etc. A small pond with a lot of fish can go fatally anoxic pretty rapidly in bad circumstances. To say that there is no benefit to aeration is unsupportable.
BR-549
Joined Sep 22, 2013
4,928
After you decide on your system control......you might consider a water pump. It is more efficient to pour the water thru the air.....than the air thru the water. As mentioned.
Is the pond stream fed?
BR-549
Joined Sep 22, 2013
4,928
I have two experiences with it. First was wastewater. Blowers and diffusers....surface brushes....and fountains, and just plain surface area....for aeration. Studies favored fountain.....but safety and odor issues were no go. Diffusers and brushes remain. That was early 80s.
And then commercial fish farms for O2 control. We design an almost totally automated cat fish farm.
Just finished tuning it and got it perfect. And then they sold it to private co. I had heard the private co. was going fountain. Was even offered a job.....but cat fish gets old. That was in the late 90s.
I haven't heard anything different....so I assume it remains true.
But they might have new techniques now.
38,762
What smart feature are you suggesting? I think even a stupid charger would work?
Stupid chargers generally will overcharge a lead-acid battery if left connected since they don't limit the charge current or voltage after the battery becomes charged.
A typical smart charger has a constant-current charge until the full-charge voltage is reached (usually about 14.4V for a 12.6V battery) and then drops to a trickle/maintenance charge voltage of about 13.6V.
wayneh
Joined Sep 9, 2010
18,151
Ah, got it. I didn't realize stupid chargers were still around because I haven't seen one for decades. My "smart" charger doesn't really seem so smart – it cycles on and off while charging because it overheats – but it does properly charge and tend a battery.
Hymie
Joined Mar 30, 2018
1,347
Personally I’d be more concerned at the food in my fridge/freezer spoiling due to an extended power outage – than any fish in a pond.
