hello, yes I know. i don’t understand it all.Hello,
0.082 k Ohm = 82 Ohm
A completely different value as the 680 k you mentioned before.
Bertus
Bertus
Thank you, that sounds hopeful.82 ohm is more like what I would expect.
I = 12 V / 82 Ω = 0.146 A
P = 12 V x 0.146 A = 1.75 W
That sounds reasonable.
Edit: 680 kΩ is most likely the resistance through your body when you were holding the meter probes with your fingers. The probes were not making contact with the wire of the coil
We don't know until we have all the details. Something is different. It could be the resistivity of the material used to make the wire.Thank you, that sounds hopeful.
What I don’t get is that the core is identical size to the original, the wire gauge is identical, the diameter and length of the coil is identical, yet the new one measures 82 ohm, the original measures 270-280 (not by me, measured by the owner.
Perhaps he has made a mistake?
Assuming these numbers are both accurate, the original having a higher resistance would draw less power. 82Ω (reasonable) is probably a slightly larger wire, which would have less resistance per length of wire and reasonable to expect a bigger coil. If the coil is the same size physically then there are less turns of wire. Also, I would expect the 82Ω coil is designed to work on a lower voltage, not on 48V. At 48V / 275Ω = 175mA. At an assumed voltage of 12V / 82Ω = 146mA. But if you use 48V / 82Ω you get 585mA, FOUR TIMES MORE current.the new one measures 82 ohm, the original measures 270-280
Agreed. The resistance changes dramatically (as the inverse of the square of the diameter) with the wire gauge.It's the wire gauge that's important.
You say it's the same , look at the resistance data for the wire .
If wire was one or two thou smaller , depending how you measured thickness ,you might not have notice.
It would let you have more wire and higher resistance .
and 30 AWG has diameter of 0.2546mmAgreed. The resistance changes dramatically (as the inverse of the square of the diameter) with the wire gauge.
30 AWG is 105 Ω per 1000 ft
32 AWG is 167 Ω per 1000 ft
34 AWG is 266 Ω per 1000 ft
| Thread starter | Similar threads | Forum | Replies | Date |
| H | Questions on RFIC and Electromagnetic design | Homework Help | 1 | |
| R | Electromagnet Turns And Same Field generated?? | General Electronics Chat | 5 |
