Electrical Socket Outlets
tahir mehmood
Joined Jun 28, 2013
27
i have a circuit having 20 amps branch breaker, the voltage is 220 single phase, how many sockets i can connect to it. i need to know the quantity once the sockets are connected in loop.
oz93666
Joined Sep 7, 2010
742
^^^ Yes .... the use of electrical sockets has changed greatly in modern times .... very rarely do they take high power ... mostly used for charging phones , low current TVs , and other low consumption devices ... So have as many as you like , in the very rare event of exceeding 20A ... that's 4.4KW !! it will only trip a circuit breaker.
wayneh
Joined Sep 9, 2010
18,104
Note that each outlet receptacle should be rated to whatever the circuit breaker is rated to, so that the breaker is protecting each receptacle against overload. You don't want a 15A receptacle 'protected' by a 20A breaker. Same for the wiring, of course.
AlbertHall
Joined Jun 4, 2014
12,625
Unless all the plugs have their own fuse, of course.
(UK local regulation)
MaxHeadRoom
Joined Jul 18, 2013
30,654
UK has what is known as a Ring Main, fed from a 30amp breaker, all sockets are rated at 13a and contain a fuse according to load.
The circuit cable leaves the service panel and picks up all outlets and returns to the panel.
Max.
AlbertHall
Joined Jun 4, 2014
12,625
And that kind of thing is why I suggested checking local regulations.
TS is apparently from Qatar and I have no idea what their domestic mains wiring regulations are.
gramps
Joined Dec 8, 2014
86
That's not entirely true, at least in the USA. It's very common to have 15 amp receptacles on 20 amp / 120 volt branch circuits.
The answer to the OP's question will depend on the country he is in and is probably dependent on local codes also
wayneh
Joined Sep 9, 2010
18,104
That's true, for a circuit with multiple outlets. Other parts of the code protect against actually plugging a 20A load into a 15A rated receptacle by mistake.
Tonyr1084
Joined Sep 24, 2015
9,744
I also have 15 amp outlets on a 20 amp service. Have seen that all my life. Only time I've seen 20 amp outlets has been in professional kitchens where someone may plug in some kind of industrial appliance that actually takes 20 amps. There isn't one thing I own that takes more than 15 amps. My wife's hair dryer is rated at 1500 watts on high. That's 13.6 amps at 110 VAC or 12.5 amps at 120 VAC. Her biggest kitchen appliance draws only 12 amps, so any typical load in the average US home is not likely going to exceed 15 amps.
