Hypatia's Protege
- Joined Mar 1, 2015
- 3,228
Oh dear! Is @Aleph(0) telling you what a slave driver I'm being! -- Wada world!Yep. Did you get mine?
Soon people will think we're conspiring.![]()
TTFN
HP
Been there, done that. HP is one of the best possible people to conspire with!Soon people will think we're conspiring.![]()
Only took me 2 British dictionaries to confirm that term used mostly by Machinists. Do you mean, "hardened"?the bearing is badly brinelled!
While indeed 'Brinell wear' owes it's name to the 'Brinell hardness test' the concepts, as a practical matter, are quite distinct albeit closely related...Do you mean, "hardened"?
--With reference to the image in post #963 (above)--What part spins
'Stickiness' at startup, highly abbreviated 'coasting time' following removal of excitation (less than 3 minutes whereas a 20 to 30 minute free 'spin down' is typical of a good bearing in a similar tube), excessive vibration and, worst of all, a 'morally excruciating' sound (appallingly reminiscent of a cremulator on bonehow can you tell?
Oh. We call that wear, galling, or spalling, depending on where the lost metal ends up.indentation of its race by it's rollers corollary to impact, static overload, or, case in point, dynamic imbalance)
Actually, true Brinelling is not owed to attrition but, rather, deformation -- below are two images (found on 'The Web') illustrative of such damage:Oh. We call that wear, galling, or spalling, depending on where the lost metal ends up.
Correct -- even a good anode bearing is quite audible -- howbeit pleasantly so!Is that the spinning sound I hear when an x-ray machine gets ready to fire?
Kool!![]()
Cremulator ... I'll never hear the sounds of this when they grind my bones.
...and when the ball-mill encounters competent bone (i.e. remains of osseous tissue having undergone only slight/incomplete thermal degradation) -- it 'raises' a peculiar 'rumbling' sound inspiring all within earshot (and possessed of the barest modicum of 'imagination') with generalized 'psychosomatic ostealgia'Ewww! Yucky!
Galling is different from brinneling. Galling is more like a welding of one metal to the other. Brinneling is what is commonly called spalling, it's when the load of a part breaks through the surface of the part, and the surface the flakes off. Even though most bearings are through hardened, the surface is harder than the under lying material. When too much load is added for too long of a time, the softer metal deforms and allows the surface to break down and flake off.Oh. We call that wear, galling, or spalling, depending on where the lost metal ends up.
Ewwwwweeeeee! I hate that phrase!the greater good
Well hey! -- My complaints about the weather doesn't mean I'm with 'The Weather Underground'!Topic will be the take over of AAC for the greater good.
FWIW All Brinelling I've encountered (which being principally in rotary wing aircraft mast bearings and RA Coolidge tube anode bearings) represents discrete 'indentations' in the race sans significant material lossGalling is different from brinneling. Galling is more like a welding of one metal to the other. Brinneling is what is commonly called spalling, it's when the load of a part breaks through the surface of the part, and the surface the flakes off. Even though most bearings are through hardened, the surface is harder than the under lying material. When too much load is added for too long of a time, the softer metal deforms and allows the surface to break down and flake off.
This is only a problem with bearing and other steels. When you get into tool steels they do through harden, because of their "chemistry" when being formed.
Brinelling of race in a sphere roller bearing (AKA 'Ball Bearing').
Being little more than a very smart repairman, I've never focused a microscope on a noisy bearing. I did not mean to derail this Thread into metallurgy, but I am grateful for the education.Galling is different from brinneling.
I cringe at the truth of that description. There is no emoticon which describes my horror about mechanical mutilation of humans, dead or alive.generalized 'psychosomatic ostealgia'
In my experience that type of damage is from a bearing being not adjusted correctly. Like in a wheel bearing on a car. Too much play allows the bearings to stop rolling and start making the indents. Timken/ taper type bearings took over ball bearings for wheel bearings, because they have more contact area and didn't destroy them selves as fast if not adjusted correctly.FWIW All Brinelling I've encountered (which being principally in rotary wing aircraft mast bearings and RA Coolidge tube anode bearings) represents discrete 'indentations' in the race sans significant material loss-- Perhaps such is unique to damage/wear owed to dynamic imbalance?
Very best regards
HP![]()
There must be...A pictorial chart of bearing failures,
#12 I don't know bearing topology but it's COOLIDGE tube not rectifierWhat shape is the bearing in that rectifier tube?
#12 standard tubes (with max anode AV ≤ 4000 RPM) are lubricated with powdered silver and high speed tubes (sometimes > 10,000 RPM) are liquid metal lubricated (which is Hg or room temperature liquid amalgam) but you'd have to ask HP how they prevent Hg vapor from ruining high vacuum cuz IDKNo lubrication?
#12 no wayNot an air bearing?
#12 even just Ag powder lubed tubes can take over an Hr to spin down from 3600 RPM when pwr is removed from stator but it's totally better to brake anode motor by applying DC to stater coil right after use to save on bearing life!I can't imagine how that thing can accomplish a 20 minute spin-down time?![]()
OK. I didn't think of a solid lubricant.lubricated with powdered silver and high speed tubes (sometimes > 10,000 RPM) are liquid metal lubricated
worst of all, a 'morally excruciating' sound (appallingly reminiscent of a cremulator on bone)...
HP OMG! That's just exactly what it sounds like! I always thought there was something more disturbing abt that noise than just knowing it's time to replace a $25k tube! Now I remember what! Tnx! NOTwhen the ball-mill encounters competent bone (i.e. remains of osseous tissue having undergone only slight/incomplete thermal degradation) -- it 'raises' a peculiar 'rumbling' sound inspiring all within earshot (and possessed of the barest modicum of 'imagination') with generalized 'psychosomatic ostealgia'![]()
As for @Aleph(0) ? -- I expect she was born four decades too late for realization of her 'calling' as a radical![]()
