Hypatia's Protege
- Joined Mar 1, 2015
- 3,228
There ya go!As close as the local(or mail order) Harbor Freight store.
TTFN
HP
HP that's a good pointThe function of metrics is obviation of assumption!![]()
HP NOW I get it cuz I wasn't thinking on how unregulated independent psu outputs can load down to different voltages when currents are differentWhile the load may be floating, the 'split' PSU is not! -- An 'asymmetrical' ground fault in an (ostensibly) floating load will result in unequal loading of the PSU 'channels' -- Said condition will not be obvious via the above described indicator...
For example -- Given a reading of 70 kV; Each channel may indeed be supplying |35|kV (as assumed) -OR- Due to unequal loading secondary to 'eccentric' ground leakage in the load, the channels may be supplying EMFs of disparate magnitudes - the sum of which equal 70kV
HP That's very good point! I know ppl who can't touch itMany people are sensitized to latex.
HP That's fine with me but IDK where we're handling chemicals in rest of seriesSo I thought to start the readers off on 'solid footing' for the series as a whole!![]()
HP I thought only blue nitrile was non porous enough for total safety?
Old proverb say: She who fish for compliment snag old boot!HP being serious you know I'm not that dumb!
There will be some solvent and adhesive 'work' in the balanced indicator 'micro tutorial' -- then too, I expect some readers may wish 'DIY' printed circuit boards (entailing exposure to 'resist', 'etching' and 'tinning' compounds). Thence, of course, in the fullness of time, dielectric oils, leaded shielding material including (not infrequently) emulsion 'slimed' leaded glass, etc... --- Point being chemical resistant barrier gloves are good to have on hand (pun intendedHP That's fine with me but IDK where we're handling chemicals in rest of series?
Aleph! please don't bet your life on the (ostensible) 'colour coding' of any manner of PPE! -- which being little more than a 'trademark' and less reliable! --- But to the 'gist' of your comment -- inasmuch we're dealing with neither pathogens nor methylated heavy metals, etc... - standard, 'home center grade' VOC/hydrocarbon barrier handwear will suffice!HP I thought only blue nitrile was non porous enough for total safety?
HP It's like when you asked me to put my correct age in my profile and I did cuz like you said wrong age was causing confusion cuz my cultural expression and references were out of sync with my generation and like that.I have, as per your suggestion, 'filled in' my profile -- Be advised, however, that's it! I'm not here to tender my autobiography!![]()
HP, nice job on the tutorial!@Aleph(0) , @Jazz2C, et al
This is to advise you that, as suggested, the Micrometer 'micro-tutorial' has been uploaded to my blog...
Best regards
HP
Hi, @shortbus - I'm pleased you approve of the Micrometer 'tutorial'HP, nice job on the tutorial!
HP I can't do anything from where I am now cuz lousy wifi with -86dBm just keeps dropping connection@Aleph(0) - Any sign of the glossary?![]()
JC!So how about the big election? I bet that little exposé that The Hildabeast and her staff are privately Anthropogenic Climate Change skeptics curried some favor with you?I share your outrage with the left's corruption and politicization of science but at least it's nice to know she (HRC) is NOT as dumb as she is corrupt!
OMG! Abt The Donald! We're totally on the same page that the sexual misconduct accusations against him are totally fabricated but IMO he deserves every bit of it as bad karma for his libelous rants towards his primary opponents!
I mean like trying to align Ted Cruz's dad with the JFK assassination
Maybe it was all a Russian plot?
(Disclaimer: Just a joke b/c I think the Russians are taking an undeserved bad rap from the current US administration and that embarrasses me to be an American right now!
) So that's abt it for politics b/c whomever wins, the Oval Office is guaranteed as good as vacant for another four years!
CorrectSay Hp, Aleph said you recently bought a set of Bicron scintillation probe modules for a Captus 2000?
Indeed! The part numbers are identicalAnyway one of my modules is marked 2m/2 and the other is 2mw2/2-x and they've both 14 pin bases and look pretty much alike. Are they the same as yours?
2M/2 describes a module comprised of a 2" by 2" (solid NaI) 'crystal' coupled to a PMT featuring a 'window' diameter of 2"Anyway one of my modules is marked 2m/2
The 'W' merely indicates that the 'crystal' features an 'end well'...and the other is 2mw2/2-x
Typical anode EMF = +900VSo anyway I'm mostly interested in the ultimate dynode voltage
Here are the pin assignments (note that pin #12 is non-connected)and a pinout
I gotta know - Is Babs participating on these fora? - Understand that I'm not asking you to 'out' her username - just tell me if she's here?How many deer would a killdeer kill if a killdeer could kill deer?
Attribution: Babs Bryant (friend and benefactor)
HP Not wanting to be an upstart but I say 950v is more typical cuz that's what Captus software defaults toPursuant to greatest PMT 'life', good design practice will not exceed 900V)
HP if you think you can have reliable access with wifi signal strength of -87 dbm (which is like 2pW from onboard Mandelbrot array) be my guest! Cuz that's all I got for almost $600/night suite before amenitiesEither 'get with it' or officially 'duck out'! -- I've had about enough of your absenteeism on a project you insisted upon joining!
HP I thought you knew Babs has been on here at least a yearI gotta know - Is Babs participating on these fora?
Hey @shortbus? I dunnoAre you people Government employee's? You've turned what started out to be an interesting thread/idea into a royal cluster f##k. No offense meant since it's your thread but come on![]()
