Hypatia's Protege
- Joined Mar 1, 2015
- 3,228
Yes indeed! Hence my suggestion in post #676 - To wit:You can get cheap HV probes and remove their multiplier resistor.
Via salvage from 'old' HV probes commonly available at 'hamfests' (i.e. electronics-themed 'flea markets'), etc... Ebay may likewise be a good contact --- Should said components prove elusive, the builder may 'string together' the requisite number of lower value HV resistors such that a wide margin is granted the maximum drop per device spec... Information Unlimited is a good source for high EMF components in 'hobbyist-friendly' quantities...
While that indeed describes a single-ended arrangement - the images in question relate to a (prospective) construction article featuring a balanced EHT indicator (applicable to floating EHT sources).Build a voltage divider and send two wires to some posts to connect your digital meter or scope.
A simplified illustration of which is given below
Many thanks for your interest!
HP
