Effect of humidity on wood
killivolt
Joined Jan 10, 2010
836
Dealing with Lacquer lately, I'm told only Lacquer will adhere to Lacquer. Polyurethaning will not adhere unless you sand it all down to the wood. Do you have any pictures? Do you need to seal around glass as well? or is the dial poking out to the clock face?
kv
AlbertHall
Joined Jun 4, 2014
12,663
It already is 'down to the wood' - all the wood is finished by sanding only. It doesn't have a pretty case with a glass front. You could call it a skeleton wooden clock.
