Dynamic test for mosfet and IGBT
gaber2611
Joined Mar 14, 2013
331
Hello everyone
It’s my first post here,
Well, I’m looking for help if circuit to make for testing mosfet or IGBT after purchase from supplier, in other words I need be able to know if the part is original or fake?
As I’m working daily on repair of Ups machines and it’s electronic circuits and they are full of mosfets and IGBT and if the part is fake , it’s a problem
I’ve searched google little, and found couple pulse test, is it ok for testing?, or you suggest better and easier circuit ?
We have variac, “ as we can get differenet voltages and rectify for dc voltage “, also function generator, 12v automotive lamp, oscilloscope and more
How can we make dynamic test for these components?
Regards
dl324
Joined Mar 30, 2015
18,477
Welcome to AAC!
If you're repairing equipment for pay, you should only use components from reputable sources.
I don't think it's practical for you to test all parameters.
You need to test as the manufacturer specifies.
Using IRLZ44 as an example.
  1. Gate leakage is measured at +/-16V.
  2. I used a PWM to test drain current at 6A. I wasn't able to test at a higher current. I used that circuit to get an estimate of on resistance.
  3. On resistance is measured using a pulse width ≤ 300us with a duty cycle of ≤ 2%. This is to prevent junction heating from affecting (increasing) resistance.
  4. Threshold voltage is measured with Vds=Vgs and Id=250uA. I had read that drain voltage and short channel effects caused threshold voltage to read low. That didn't turn out to be the case. I initially measured threshold voltage by using the MOSFETs as a current sink/source. Then designed a circuit to measure with the drain and gate shorted together. Doing it correctly gave slightly lower threshold voltages, which was the opposite of what I was lead to believe.
I bought 4 types of MOSFETs from AliExpress and had to test 100% of the devices for gate leakage (because they were all packaged in plastic bags), on resistance, current up to 6A, and threshold voltage. I used 3 different circuits and just used an ammeter to measure gate leakage.
I know the dubious origins of these parts and they won't be used in any critical applications (hobby circuits only). I bought them because I was looking for affordable power MOSFETs. I'm retired and it was worth my time to pay a fraction of what the parts would have cost from a reputable source and have to test them.
MisterBill2
Joined Jan 23, 2018
28,424
In general, a gate leakage test setup can combine with a turn on/turn off test setup. a set voltage which should keep it off, thru a big resistor, another voltage that should switch it on, thru some resistor, and an incandescent light bulb as the load for the ON/OFF part of the test. AND YES, devices used for repair should all be checked. Getting them from a legitimate source does make passing the test a lot more likely.
gaber2611
Joined Mar 14, 2013
331
Thanks everyone for respond to my post , and all your replies are very good and useful
Well, anyone know a tester we can buy for this purpose?, and help identify if the part is fake or original?
LowQCab
Joined Nov 6, 2012
5,102
There are certain aspects regarding the methods of construction that can not be tested,
unless You go straight in with the intention of testing to destruction.
If a project is worth doing, then it's worth doing well, right from the start.
dl324
Joined Mar 30, 2015
18,477
None that I know of. Even manufacturers don't test all parts for all parameters. Some are guaranteed by the manufacturing process, some are sampled, some are 100% tested.
If you're not buying from a reputable source, you have no way of knowing if you're buying rejected parts (i.e. something someone literally picked out of the garbage and is selling), remarked/counterfeit, or genuine. You can test for the parameters that are important to you. There are some obvious signs on some counterfeit product.
I bought some IRF9540 from AliExpress. The on resistance seems to be 2-3X higher than what the datasheet specifies. Maybe I got some IRF9520's that were relabeled, maybe they were rejects, maybe they're some other P channel MOSFET. What was important to me was that they be P channel and have a high enough drain current with an on resistance that was low enough.
Since the on resistance was a bit high, I bought some IRF4905 that have a tenth of the on resistance of IRF9540.
MisterBill2
Joined Jan 23, 2018
28,424
The test I suggested was to verify that a device could work in a specific application. Not every counterfeit is a failed part, and so they might work in some applications.
LowQCab
Joined Nov 6, 2012
5,102
If You drastically over-specify the part from an "iffy" Supplier,
it is less likely to fail, and it will probably perform adequately.
But there's no such thing as a "too-good-to-be-true", ~$0.35 cent MOSFET.
You are probably paying more in shipping-costs than the actual component costs.
An extremely High-Power-FET is still usually less than ~$5.oo each, from a reputable supplier,
I just can't understand what the huge problem is.
I've never had to set-up a comprehensive-testing-rig for any Component from DigiKey or Mouser,
that alone is worth serious actual Money, and Time, which is also Money.
MisterBill2
Joined Jan 23, 2018
28,424
A Pass/fail test that takes much less time than replacing a defective component will be an advantage if purchasing has got a bunch of questionable components. But for products either easy to repair or not worth repairing, testing does not make sense.
38,861
Even if the part passes all the tests you can think of, it still may exhibit a high rate of "infant-mortality" because of poor manufacturing quality control.
As the old English saying goes You are being "penny-wise and pound-foolish".
MisterBill2
Joined Jan 23, 2018
28,424
Certainly there is a very big difference between an individual purchasing a part and a purchasing person deciding to buy a bunch of parts from a questionable source, which is what I was referencing. And even for a hobby-level project, it can be very handy to know that a part is not a totally failed counterfeit before installing it in some project.
graybeard
Joined Apr 10, 2012
118
I find the curve tracer in Digilent's Analog Discovery Waveforms software to be helpful. I use it to see if the transistor is working or not and to compare the curves from multiple transistors to see how consistent the transistors are with each other. It's only low voltage, however.
I find the Analog Discovery tool to be a very flexible addition to the tools in my lab. You should check it out. It's a little pricey, but not for what all it can add to your lab.
gaber2611
Joined Mar 14, 2013
331
Can you show me this tool?
graybeard
Joined Apr 10, 2012
118
I have an Analog Discovery 2 that I bought a long time ago: https://digilent.com/shop/analog-di...ope-logic-analyzer-and-variable-power-supply/
They now have the AD3 (which I have not used): https://digilent.com/shop/analog-discovery-3/
They are controlled by PC software called Waveforms: https://digilent.com/shop/software/digilent-waveforms/
That page doesn't show all of the functions in the software. You should download waveforms software and try it to see all of the things it can do.
Unfortunately, they look like they are currently sold out. :( Looks like Digikey has a few AD3s: https://www.digikey.com/en/products...aIIYDs4BsD2BzABAEwJYGcBjVANwFMAnAT0wGYQBdAXyA
I also bought the curve tracer accessory (but you don't need it to test transistors. It's just convenient): https://www.digikey.com/en/products/detail/digilent-inc/410-413/14305460
EDIT: You might find these videos a faster way to learn about it: https://www.youtube.com/results?search_query=digilent+wafeform+capture
gaber2611
Joined Mar 14, 2013
331
THanks a lot for your intentions to help
I still don’t know how use this device for test transistors so I know which fake and which original
And by the way it seems expensive device, around how much you think is this?
graybeard
Joined Apr 10, 2012
118
It is a little expensive, almost US$400, but it is a very powerful tool, giving your lab a lot of functions in a small package. It can show you if a transistor is functional and if a lot of them are consistent with each other. But it can't show you if the transistors are counterfeit.
