Dual switch with two outputs and constant third
lukxa
Joined Jan 17, 2023
13
Hello everyone,
I made 3 fans for resin 3d printer enclosure. 2 of those are main fans to take air out of chamber and third one is inline fan to push air further down the pipes. I have 2 switches and want to wire 2 main fans to those switches so one switch controlls one fan. How can I connect the third fan so that when any of two main fans are on the third fan also turns on. I have tried a few schematics, but none of them work. Thank you for any help.
djsfantasi
Joined Apr 11, 2010
9,237
What is used to power the fans? Voltage? AC/DC? Do the fans each have one side tied together?
It could be as simple as adding two diodes…
LowQCab
Joined Nov 6, 2012
5,102
Or replace the existing Switches with Double-Pole-Switches.
This would be the simplest solution.
Do You have a part/number, or PDF, for your existing Switches ?
Pyrex
Joined Feb 16, 2022
577
Two relays with 230VAC coil and 1 NO contact. Coil in parallel to the fan, same Fan N#1 and Fan N#2. Both NO contacts in parallel . They will power on the third fan
lukxa
Joined Jan 17, 2023
13
Thank you for great idea, but I am trying to make it work using only switches.
38,952
So connect the switches as follows:
Below -- Pin 1 to the 220V, pin 2 to it's respective main fan, and pin 3 in parallel with the other switch pin 3 to the inline fan.
Pins 2 and 3 can be swapped if that makes the wiring easier.
Make sense?
38,952
I do have two, but if I make parallel connection between pins 3, current will travel between both switches, so all fans will turn on.
No.
Not if the switch works as shown on its schematic.
Yes, the voltage will be on both pin 3's if one switch is on, but it will not go to the fan whose switch is off, since contact 3 is open when that fan switch is not on.
LowQCab
Joined Nov 6, 2012
5,102
That is a special proprietary Switch,
there's probably nothing You can change about it, or the way that it's wired.
Make a Blank-Cover for the Junction-Box and install 2 standard Double-Pole Switches.
