Dryer repair:
Hansen
Joined May 3, 2015
30
Your meter does not really know where ground is. It only reads the voltage across the probes. So when the meter reports L1 to Ground = 0V It only tells you there is no voltage difference. I think L1 does not equal 0V but ground is at 110V.
Is there a ground from a different circuit nearby you can get to. (from a 110v plugin) Use a copper water pipe as ground. The point is I want a meter reading from a known ground and not that outlet. I know I said this several time but your ground is not connected or poorly connected.
When I used a copper water pipe as ground for the meter, I still get the same readings:
L1 120v L2 120.
When I hit the start button, L1 goes to 0V and L2 goes to 240 V
