Hello all,
I have an electric clothes dryer that has decided it wants to dry no more. I am reluctant to send it to white good heaven as Zanussi would hope. I have began an thorough investigation into the matter employing all my limited resources, and believe me they are limited, creativity and knowledge and have come up completely stumped, I appeal to all who are knowledgeable in such matters to assist, throw me a line.
The beast shows no sign of life at all, dead she is, aye dead, no leds or beeps or even rapid eye movement, I have checked the obvious, plug fuse, power at socket, and temp. sensor, even checked to make sure the electricity was'nt cut off.
But seriously looking online several sites list powerboard issues a common problem for washers and dryers, specifically LNK chip failure.
If this IC fails/shorts there is a 3 watt resistor (mine 47ohm) which acts as a fuse and blows open.
I removed my board and this resistor was indeed open, I replaced the resistor with same,which just blew open when powered, typical; I then ordered a repair kit from fleabay which had a LNK304GN chip and a 3 watt 47ohm resistor.
I replaced the chip and resistor but the board still shows no sign of life.
With the board removed from the machine and connected to the mains some leds should light on the LNK chip side at power on.
I am using a isolating mains transformer as some form of safety.
The new 47ohm resistor is ok
I have removed and tested diodes marked with a circle, ok
Checked diode above the LNK chip ok
Caps marked with an X have no charge (low power 35v caps), high volt cap marked with a tick mark is charging 320v.
Also checked opto coupler and opened rotary switch and cleaned with alcohol.
Checked L, 3 in total, I think chokes?, interfernce suppression? they show conductivity.
The Link chip seems to be outputting nothing, there is 5.8v at the bp pin 350v at the drain and .5v at the fb pin, ov at source pins.
I have looked at the chip data sheet but this is beyond me, and causes severe pain in my brain, I cannot find a schematic online.
Are there other common components beside the LNK IC that fail on these boards?
Is there a way of testing the LNK chip?, is chip removal required for testing?
I only have a digital multimeter for testing and a very limited knowledge of electronics.
Any suggestions would be greatly appreciated.
