DRV8313 motor driver chip does not function as expected - simple circuit!
Elazar
Joined Oct 29, 2019
49
Hi All,
This is part of a very simple experimental circuit,
and somehow the DRV8313 motor driver chip does not function as expected,
when the circuit is powered on the DRV8313, motor_1, motor_2, motor_3 pins output the desired voltages, BUT once I connect any motor load, the chip turns off right away.
The datasheet states that it can handle up to 2.5A and the motor I have connected is less than 1.5A (for a very short amount of time)
Please see datasheet: https://www.ti.com/lit/ds/symlink/drv8313.pdf?ts=1618735338519
I don't see anything wrong with the circuit design.
The code that runs, is a simple test code to enable and test the chip
See the simple code below:
C:
#define EN3      8
#define IN3      9
#define EN2      10
#define IN2      11
#define EN1      12
#define IN1      13
#define NRESET   A0
#define NSLEEP   A1
#define FAULT    A2
#define RELAY_1  4
#define RELAY_2  5
#define RELAY_3  6
void setup() {
  pinMode(EN3,  OUTPUT);//EN3
  pinMode(IN3,  OUTPUT);//IN3
  pinMode(EN2, OUTPUT); //EN2
  pinMode(IN2, OUTPUT); //IN2
  pinMode(EN1, OUTPUT); //EN1
  pinMode(IN1, OUTPUT); //IN1
  pinMode(NRESET, OUTPUT);//NRESET
  pinMode(NSLEEP, OUTPUT);//NSLEEP
  pinMode(FAULT,  INPUT_PULLUP); //FAULT
  digitalWrite(NRESET, LOW);
  delay(100);
  digitalWrite(NRESET, HIGH);
  digitalWrite(NSLEEP, HIGH);
  digitalWrite(EN1, HIGH);
  digitalWrite(EN2, HIGH);
  digitalWrite(EN3, HIGH);
  digitalWrite(IN1, HIGH);
  digitalWrite(IN2, LOW);
  digitalWrite(IN3, LOW);
void loop() {
  delay(2000);
AlbertHall
Joined Jun 4, 2014
12,653
Your circuit is missing some capacitors recommended in the datasheet.
The motor will draw a lot more than that 1.5A at start up and that may be hitting the overcurrent protection in the chip.
Elazar
Joined Oct 29, 2019
49
You are correct!
I have placed a 470uF capacitor on the VCC next to the chip and it started to work!
Thank You!
