Driving TWO dual-coil latching relays from a D-Type FF?
Schluppy
Joined Jun 7, 2024
39
You're correct, it is the same as using two MOSFETs, but it comes in a single 8 pin package.
HUGE real estate savings compared to two 4049s!
However, if I'm understanding the datasheet correctly, the 40107s would require a pull-up resistor on each output and a diode parallel to each parallel coil set coil in each relay. So, 6 4 2 additional components. Is that correct?
Schluppy
Joined Jun 7, 2024
39
The diodes can be placed at each 40107 output (diode anode) to V+.
Just to remove any ambiguity, that means a diode between pin 3 (cathode) and pin 8 (anode) and another between pin 5 (cathode) and pin 8 (anode). Is that correct?
Forgive my noobness. I'm still learning the nomenclature. "V+" in this instance is the same as "VDD."
28,249
The turn off is still not instant and so there will be no generation of any spike due to the instant cutoff of coil current, because the current decays slowly as the capacitor charges.
38,802
That may be true for a single MOSFET, but not necessarily for a CD4000B series device, which has a much higher gain due to having at least two stages from input to output.
Below is the I/O transfer function for 5V and 15V Vdd from an RCA app report
Note that it takes a only a few hundred mV change on the input for the output to go from Vcc to 0V.
On that basis I think the output could transition fast enough to cause a transient spike from the relay coil inductance, even with the slow input RC fall time.
A couple added diodes is cheap insurance against a possible damaging spike.
